- Sun Dec 06, 2020 4:14 pm
#94341
I've just got a new petrol tank for my Indian 350 bullet trials bike.
The price of an alloy one means I couldn't justify getting it all battered and scraped, and it's an actual trials bike for use in competition so it WILL be fallen off -probably on every second stage with my current skill level- so I went cheap.
So it's basically a considerably cheaper (and heavier) steel version of the alloy trials tank. I got it from an Indian company who also do alloy tanks on the basis that if they can weld alloy, they can probably weld steel properly.
Remarkably, it is fuel-tight, the cap fits and so does the fuel tap. Predictably, they did something totally stupid and painted it inside and out with a non petrol-proof grey primer
. Anyway, after much ado with acetone I've got it all back to bare metal and have lined the inside with POR15 so it'll be ethanol and rust proof (better to line it now than remedially line it after it starts leaking).
So the question. How does it mount? It's got the traditional mounting on the front to bolt through the frame. At the rear there is a kind of peg-thing. I'm going to guess I need to put a piece of rubber over the back of the frame spine for it to rest on? Then presumably there is something like a giant rubber band that loops under the frame and attaches to the peg either side (I'm thinking vacuum cleaner drive belt)? Or maybe some sort of strap?
There is presumably a proper way of doing this so I thought I'd ask before just making something up.
