- Fri Dec 04, 2020 5:12 pm
#94319
Sorry, I don't have a meter! I have to use more crude methods. You're not the only one on this forum using one though, so somebody might be able to oblige.
It's possible there could be a condenser issue, but the cut out shouldn't affect it unless the kill switch isn't returning to the open position properly or the wire's shorting somewhere. Does it start more easily with the kill switch disconnected? If so, problem located, if not, new condensers are cheap enough, our hosts list them a £4.40 + the usual.
I seem to recall reading something back in the mists of time about the SR2-fitted twins not being the easiest to start, there is presumably a reason why Redditch abandoned the SR2 for the K2F magneto. Shame, as the rotating magnet design is better and condenser replacement (should it be needed) is MUCH easier.
