By windmill john
#96423
I was going to raise the issue that carbon build up increases compression ratio.
So the only thing I can think of is that, the carbon is rough and can affect the flow, swirl, of the incoming mixture and burn.
Mine did just that recently, but it stopped from idle so thankfully the valve wasn't damaged at all. It still resulted in a top end overhaul to get compression back.
  • 1
  • 3
  • 4
  • 5
  • 6
  • 7
