Kick back on Electra x
Posted: Thu Nov 26, 2020 4:41 pm
by David Crossley
Hi folks I have removed my electric starter from my Electra x 2006. After distroying my sprag clutch, so as a kick only bike now I have noticed an increase in kickbacks. I know I can purchase an advance spark unit. Will this help or is it more of a carb problem. Any advice appreciated. D
Re: Kick back on Electra x
Posted: Thu Nov 26, 2020 6:18 pm
by ericpode
I think it is generally agreed that most Electras are already over advanced David so you don't need an "advance spark unit"
There are mechanical means of retarding your spark a few degrees including special rotor keys from our host. Search this and the other forum and you should see a lot of info on this subject.
Posted: Thu Nov 26, 2020 9:12 pm
by Bullet Whisperer
Hi David, you might find this could be worth trying.
https://youtu.be/axOs4qRkob8
Posted: Thu Nov 26, 2020 9:23 pm
Refining your starting technique as above is a no-cost solution.
The "advance spark unit" is in fact a spark DELAY unit to allow the engine to rev up a little on the starter motor before the sparks start to happen, primarily intended to save the very E/S sprag clutch which you have removed, so you don't need one of those.
Posted: Fri Nov 27, 2020 9:14 am
by papasmurf
Make sure the piston is past TDC before you kick it in anger.
Posted: Sat Nov 28, 2020 10:59 pm
by David Crossley
Thank you so much I will take on board all advice, look into my technic of kicking over. Thanks for the advice of the advanced ignition.
I will post all further results. D
Posted: Sun Nov 29, 2020 5:24 pm
by John-M
keep the throttle closed or nearly closed, wide throttle openings are good for inducing kick-backs. As you have already discovered, kick backs are great for destroying sprag clutches
