Presto wrote: ↑Mon Nov 23, 2020 4:16 pm
. Nor do I understand how the length of the exhaust pipe would alleviate this problem.
But anyway...
BW you are correct. I guess from the pack of dogs type attack I was confused with who said what.
It was Presto said that.
You have very little wriggle room to tell me I am a liar I did not say you should not ride in bad weather or what bike to ride. That is just ridiculous.
Reversion is shock. It has nothing to do with valve timing in its origin . However the shock returning back up the pipe which is on the outer edge of the pipe will travel right across the combustion chamber and out of the carburetor if the VALVE TIMING will allow. I don't know where you are looking at all but spend a bit longer than 30 seconds.
If the down pipe is long it will be later, if it is short it will be early. Exhaust gases need to travel at 300ft per second for scavenging but again that is not thermal or sonic shock(reversion). A good long system will bring it so late as not to be a problem the 500 UCE is very long, beginning to sound like something is going on???
Have you ever seen fuel in the mouth of the carb and wondered how that got there, well now you know.
You are correct on the overlap and exhaust open but not half way down the stroke. what you mean is the exhaust will open half way down the POWER stroke ,--not BE OPEN half way down the stroke.
I have things to do and I will not be taking this any further until there is a proper conversation at least by some one that knows what the subject is.
