By 73a
#93763
i have a 1983 classic 350 bullet engine which i am rebuilding , when looking directly at the primary case which direction does the engine sprocket rotate when the engine is running ?
i am asking this as i am fitting a new duplex chain with a connecting link hence asking for roation direction.
thanks ng
#93768
Although in fairness, fitting an endless one is pretty easy.
Don't know how big a job you're doing but remember, if you are going to want to change the front sprocket, the whole primary drive will need to come off anyway, that's the ideal time to swap out the primary chain.
