- Thu Oct 22, 2020 4:09 pm
#93650
Im looking to buy a second hand 5 speed box. will the Indian 4 speed clutch fit? thanks
Very impressive knowledge.Wheaters wrote: ↑Thu Oct 22, 2020 7:17 pmYes, I converted my 350 to a 5 speed box.
The input shaft of the 5 speed box is slightly different. You will need a new clutch hub (the most expensive new part after the gearbox) a new self locking nut to hold it onto said shaft and a different oil seal plate for the rear of the primary chain case.
The rest of the 4 speed clutch can be used.
