Classic 350 iron barrel timing shims
Posted: Wed Oct 07, 2020 6:33 pm
by 73a
My exhaust and inlet timing cams have two shims each , should there be one each side of the cams or both between timing cover and cams ?
Re: Classic 350 iron barrel timing shims
Posted: Thu Oct 08, 2020 7:26 am
Both on the outside but i can't see that it would matter.
Posted: Thu Oct 08, 2020 7:39 am
by 73a
Thanks for reply , that was my thinking just making sure it didnt act like a thrust washer.
Posted: Thu Oct 08, 2020 8:29 am
AFAIK they just take up the end play.
Just be careful what gasket you use; there are some thin ones about that will allow the cover to jam the cams regardless of the shims.
