- Thu Oct 08, 2020 3:37 am
#93403
Its a whirring noise and a clanging noise. The piston slop totally unacceptable and is a good candidate for the clanging.
I started to re build and then I noticed the Timing side crank bearing was infact --not perfect I had .025mm play.
I drove over 150km yesterday looking for a piston in many many shops and engineers. The language was a barrier but I struggled through. I came home without a bearing or a piston.
The bearing is ordered from the bearing factors near buy . I have managed to find a piston from a Honda generator at 88mm with a 20mm pin and 20mm compression distance, this was just under 8 quid with rings, pin and clips.
The piston is 88mm so Im not sure wether to skim that on a lathe or make a new liner or both.
Any one clever enough to work out the new capacity of a 88mm. It looks from the picture to have a dish as is the same but with 4 little notches for the 4 valves. Pretty cheap at 8 quid and worth it just to look at it. I spent quarter of a tank of Deisel yesterday for nothing,--that was 10 quid.
