- Mon Sep 14, 2020 3:41 pm
#92969
The battery on my Euro C5 went flat and after charging now goes flat every few days. After charging it and leaving it for a day it only reads 11.1v. So i have bought a new battery, however when connecting it up as soon as I connect the wiring terminals the EFI pump turns on continuously (ignition key switch is off) if i turn the ignition key on then the fuel pump operates continuously as well as the EFI pump!! I am doing anything wrong. Nether were doing this before i took the old battery out.
Thanks
Thanks
