UCE EFI RPM
Posted: Sat Sep 05, 2020 5:20 am
by Cranky
Can any of you guys with a tachometer please tell me what RPM a UCE EFI revs to.
Like say what RPM would you have in top gear at 100 kph.
Do you find it has a sweet spot where it pulls better or does it pull the same all the way through.
What is recomended max RPM. Does the ECU have a rev limiter.
Re: UCE EFI RPM
Posted: Sat Sep 05, 2020 7:08 am
by windmill john
It’s on here somewhere. I think the Rev limiter is around 5750; of course that could have been wrong!
Re: UCE EFI RPM
Posted: Sat Sep 05, 2020 7:59 am
by Cranky
5100 seems to be where max hp is produced.
Crickey thats a lot. So what is max rpm.
Mine shakes the handle bar really bad at 40kmph. I dont want a tacho- i dont want to ever tske it up there.
Re: UCE EFI RPM
Posted: Sat Sep 05, 2020 9:58 am
by Haggis
at 40kph you will still be in first or second gear....?
I hope your not trying to pull top gear at that speed.?
Re: UCE EFI RPM
Posted: Sat Sep 05, 2020 10:29 am
by Haggis
Re: UCE EFI RPM
Posted: Sat Sep 05, 2020 2:16 pm
by Rattlebattle
Mine only just pulls 40mph in top, but I have geared it up one tooth to shift the chronic vibes further up the road speed. 40kph in top will knock the big end out prematurely.
Re: UCE EFI RPM
Posted: Sat Sep 05, 2020 2:38 pm
by Cranky
Well that tells me everything, thanks for that. I don't know where you guys get this stuff.
