Changing the fork oil on 500 EFI fork legs. Some tips.
Posted: Sat Aug 29, 2020 12:46 pm
I'm just in the process of fitting a set of second hand B5 fork legs to my 612 bullet.
Just been going online to see how much fork oil they need (seemed prudent to change it before fitting them) and it seems others have already run into the same issue I just had ie. the top caps are in EPIC tight. These ones have certainly never been out. It seems many owners are actually just emptying and filling them from the bottom.
Here's how I did it:
First off, the top cap is a reverse thread, clockwise to unscrew. It has a recessed 12mm hex. The chromed slot-headed top-caps in the end of them are purely decorative (well, they also prevent water trapping) and are conventionally threaded.
The hard bit of this job is holding the fork leg tightly enough to unscrew them without damaging the fork, this is where people are falling down, I've seen multiple threads on the subject all over the internet. My top tip is to clamp it in the bottom yoke. I'm fortunate in that I had a spare one. I clamped this in a vice and clamped the fork in the yoke. In any case, first time doing this job, you're probably going to need to set aside half a day and get the forks out of the bike and onto the bench. You might want to remove the bottom yoke (or buy a cheap indian one to use as a clamp).
I then had to apply a lot of penetrating oil to the cap then a lot of heat to the outside with my burner torch. It still took a great deal of force to undo! The ideal would be a burp-gun with a 12mm impact bit, I'd expect that to waltz it out. As it was, I used a big allen key with a bit of pipe and whacked it a few times with a hammer to shock it into moving.
It'll be reassembled with plenty of anti-seize compound on the threads/plug and it should only really need to be nipped up, there is no way it can unscrew when the fork is fitted ont he bike. I expect it to simply unscrew next time.
For future fork oil changes, I think the procedure will be to unscrew the fork from the casquette and slide it down so it's sat just above the bottom yoke. Clamp the yoke again and it should be simple enough to unscrew and remove the top plug with a long hex bit.
I also think it would be possible to do the initial removal like this IF you have a burp gun and a long reach kex-key. Otherwise you'll need it off the bike so you can get some heat and leverage on it.
I can't see a dealer doing this. I'd be prepared to bet if your 500EFI has only ever been dealer serviced, the fork oil has never been changed.
