- Sat Aug 29, 2020 10:08 am
#92561
After lots of discussion about oil pressure on the EFI engines (or lack of it) I decided to find out just what pressure I had.
Upon removing the RHS cover I found the oil pump/ filter housing O ring to be crushed down to about half it's width which would suggest it was making a decent seal but when left for a few hours it did not recover it's shape which suggests it's not particularly good quality.
I replaced it with a viton item which I fixed in place with a dab of grease (I'm not convinced superglue is a good idea)
I then fitted an oil pressure gauge by drilling that blanked-off drilling into the oil filter chamber.
I made up a brass adaptor threaded M8 and tapped the case.
The gauge is a 1/8 BSP thread and I don't intend to leave it there all the time; it's just for checking the oil pressure periodically. I have a blank to cap off the brass adaptor which will be left in place so the thread into the case will not be disturbed every time I check the pressure.
I do understand that the oil pressure will be worryingly low at tickover with a hot engine but as long as I get a decent value at running speeds it will be OK.
I understand these engines don't have very high oil pressure anyway.
At least the figures I got prove that the oil pump is working and the seal is doing it's job.
Of course, the next step is to prove decent oil flow to the top end!
Cold engine - tickover 45psi - 75psi when revved.
Warm engine_ tickover 20psi - 55psi when revved.
I'll try to link the video I took (just on the phone - not brilliant quality)
https://youtu.be/Sjv_0pK_mUk
Classic C5 Euro 4 at the moment.
Also CBf250.
Also CBf250.
