Page 1 of 3
AVL head torque
Posted: Sat Aug 15, 2020 10:30 pm
by Allanfox
Sorry if a pretty basic question but my manual has two conflicting torque settings for the head nuts on my 500 AVL engine, it has 24 and 33 Nmtrs mentioned in different places, anyone know which is correct?
Re: AVL head torque
Posted: Sun Aug 16, 2020 1:40 pm
by Jojje
I remember wondering these figures myself. Explanation is simple: 24 stands for "ft/lbs" which corresponds 3.3 Nms.
Re: AVL head torque
Posted: Sun Aug 16, 2020 2:06 pm
by Allanfox
Thanks Joffe, thought you had it but both are N/Mtr? Just a tad confusing!!
Re: AVL head torque
Posted: Sun Aug 16, 2020 2:29 pm
Torque wrench? Just nip the head nuts up nice and tight (by feel), and again after a hundred miles or so.
Re: AVL head torque
Posted: Sun Aug 16, 2020 3:08 pm
by Cranky
Adrian is oh so correct. Don't use a torque wrench on Royal Enfields --just tighen it up snug.
Let me tell you a little story. When I went to RR school at Wilsden Green in london, a kid asked why don't RR give torque settings. The teacher with a waxed mustache in a white coat ( the teacher was in a white coat not the mustache) said if you dont know when a nut is tight we don't want you working on our engines.
In 1969 the only torque setting they gave was for the Mk v1 and that was a 6 cylinder with 39 1/2 inch studs.
As tight as you can with a 6 inch bar.
Applicable to anything
Look at the material and the thread and the size.
Re: AVL head torque
Posted: Sun Aug 16, 2020 4:13 pm
by Allanfox
Cool and I am of the same school to be honest, funny If they didn’t publish torque settings I wouldn’t be asking, only ever give it thought on head nuts, in other areas I do go with feel. Thanks and good too about 6” bar!
Re: AVL head torque
Posted: Sun Aug 16, 2020 5:12 pm
I sent my old Electra-X's crankcases to someone who'd used a torque wrench to tighten up the banjo bolt at the bottom of his Electra-X crankcases. OK, set wrench to the figure in the book (presumably) wind it on and
CRACK! He then gave me the damaged crankcases to play with. Once the JB Weld emergency repair was cleaned off, this is what it revealed. At least the cylinder studs use a metric coarse thread, this one is M10 x 1.00, I think.
Re: AVL head torque
Posted: Sun Aug 16, 2020 5:35 pm
by Jojje
Allanfox wrote: ↑Sun Aug 16, 2020 2:06 pm
Yes, I have the same book. I've used 33 Nm in my Electra and nothing's broken.
Re: AVL head torque
Posted: Sun Aug 16, 2020 5:43 pm
by Jojje
Yes, I have the same book. Printers make mistakes. I've used 33 Nm in my Electra and nothing's broken.
Re: AVL head torque
Posted: Mon Aug 17, 2020 8:50 pm
I'm old school and don't use a torque wrench much.
Except! Steel studs into alloy! It's oh so easy to overdo it. Steel on steel you have plenty of leeway but not steel into alloy. On fact, strictly speaking, you shouldn't do steel to alloy, there should be an insert.
You'd never find a alloy thread on anything really critical like an airframe.
