- Wed Jul 29, 2020 9:55 pm
#91851
Yes, that is a known issue. The groove machined into the plate is wider than the o ring usually supplied. This results in a small leak which some owners, and possibly dealer “mechanics”, then try to stop by tightening the two bolts a little more. You can guess the result. The oil filter plate o ring sometimes leaks for the same reason. On the main drain plug the problem is not helped by the RE manual advising the use of thread sealant. I’d rather put up with what isn’t usually much of a leak than stripped threads. In my experience they usually seal themselves anyway.
As has been said, there are many happy owners who have had no issues with their UCE singles, but there are a lot of low mileage ones for sale out there too. As most will know, they are not making any more 500cc bikes, probably because they wouldn’t pass Euro V and, more importantly, the Indian equivalent. These bikes are likely to become similar to the iron barrel models, eventually reaching classic status in their own right. I’m keeping mine because I now know its internal condition, it’s been upgraded bearing and exhaust valve-wise and it’s really handy for local and winter use and is just so easy and convenient to ride on my own ( ie not with other riders). For me it really isn’t a suitable candidate to be my only bike or to do serious mileage on, solo let alone with a pillion, but for light local use it’s fine.
BTW I wouldn’t take pleasure in someone’s misfortune with their bike, whatever it is. I know just how depressing it can be, forewarned or not.
