- Wed Jul 22, 2020 8:40 pm
#91695
Hello again, went for a blast today and the engine occasionally coughs if you give it a fistful to quickly, it doesn't surprise me that big singles do this when cold but mine does it when hot also. It has actually died a couple of times when pulling out which is a bit disconcerting to say the least! As the bike had been laid up for so long I have ordered some new fuel pipe (very hard/brittle) and mini filter between the petcock and carb, also carb gasket set. The points look ok but might look into an electronic ignition set up if its not too costly, not sure what else to check? any thoughts welcome, Kally
