500 AVL engine fitting
Posted: Sat Jul 18, 2020 10:14 pm
Hopefully will be putting my engine back in the frame in the not too distant future as starting to build it up, finally!
Do you fit the engine/gearbox with gearbox hangers bolted to the assembly or do you fit the hangers after the engine/gearbox assembly is fitted? The frame as really clamped up where the hangers fit so guess I will have sprag it out a bit to allow them to fit?
Also, which side is it best to tackle it from, manual shows going in from the primary side, I think as the manual photos are really bad!
Any top tips appreciated!!
