- Sun Jul 05, 2020 3:26 pm
#91281
Hi,
if anyone has a spare EFI barrel (or your one-and-only is off the bike for any reason), please could I ask someone to let me have some measurements off it? I know the CGT barrel has a larger outside diameter cylinder liner as well as the 87mm bore, but I'm guessing the rest of the dimensions are the same.
What I'd like to know is:
1. What is the height (or depth) of the finned alloy muff from base gasket face to head gasket face?
2. What is the height (or depth) of the exposed cylinder liner below the base gasket face?
3. What is the total width of the top fin, measured both across in line with the crankshaft and fore-and-aft?
4. What is the distance from the edge of the cylinder bore to the edge of the fin on the side opposite the push-rod tunnels?
Thanking you in advance,
