By Pict - Mon Jun 29, 2020 4:42 pm
#91136
The two primary sprockets have never been in line since I’ve had the bike and as I was looking for a job to keep me busy
I made up a slim spacer for behind the crank sprocket and the two are now perfectly aligned. So far so good. But now with the spacer that goes between the sprocket and the rotor fitted, the woodruff key can’t seat.. the spacer is too far out (man).
So, what do you think?
a. Throw away my spacing piece, the primary chain has coped with the misaligned for a long time.
b. Turn down the spacer between sprocket and rotor
c. Grind a bit off the woodruff key
Funny how doing the right thing has potential to end up in a colossal bodge
