Page 2 of 2
Re: Putting the trials bike on a diet?
Posted: Mon Jun 29, 2020 6:47 pm
Beezabryan wrote: ↑Mon Jun 29, 2020 5:46 pm
My understanding is that the tank on enfileds is a partly structural member?
How does that work?
It's not Bryan. I don't know where this comes from but I've seen it quoted a few times.
It is true that some bike frames do rely on the tank for structural strength. Tiger Cubs were a bit suspect off road without a steel tank. We used to but a brace up in the tank tunnel as a stiffener when using the bike for trials with alloy tanks. Some of the real trick Cubs had an oil tank under the tank acting as a brace.
Posted: Mon Jun 29, 2020 7:31 pm
by mart
Top yoke PART No. SPECIAL35878 is cheaper and you can cut off the speedo hoop, ali rims ( 21 inch front) ali tank, ali or plastic mudguards, small non sprung trials seat, drill all the bolts, ali bodied shocks, ali engine plates, loose that rear frame, 1/2 width ali rear hub with ali sprocket, Continental GT swingarm, 520 chain and sprockets, smaller battery?? the smallest LED rear light you can find with a plastic mumber plate bolted direct to the mudguard, fit the smallest headlight you can find, ali levers and a Crusader frame. Every little helps as they say at Tesco! Oh and drill holes in everything.
Posted: Tue Jun 30, 2020 9:08 am
by vince
Hi, Alloy rims, hollow out all bolts, alloy engine plates. Look at each item and ask yourself how can I lighten this. Just by removing unnecessary items can save a lot in weight. . A redditch sold trial bike was about 309lb try getting to that as a target. Vince
Posted: Tue Jun 30, 2020 11:01 am
by stinkwheel
Be interesting to weight it actually. I'll nick some bathroom scales and weigh each end...
Posted: Tue Jun 30, 2020 12:21 pm
by trophyvase
As a lesson in ultimate weight saving on a 'classic' take a look at Sammy Miller's Ariel.
Weight saving without compromising strength.
I think it was a 'winner' too!!!!
Posted: Fri Aug 07, 2020 1:20 pm
by Nitrowing
I'm going down a similar route with my 2005 Electra X, so I'm interested in what you can find.
I swapped to alloy bars - 450g saving
Engine plates - 580g saving
Kickstart lever - 650g saving
I'm looking for a plastic or alloy chainguard
I'll change most of the bolts for alloy and titanium
Our host's fork brace is far too bulky but a lighter one with glass/carbon mudguard would be great.
I'm awaiting a fiberglass rear mudguard.
I looked at swapping the steel rims for alloy but the cost...
Posted: Sun Aug 09, 2020 7:00 pm
by mauri
recently weighted mine, at 131.8kg with 2 liters of fuel im getting close to my target weight of 125 kg.
Posted: Sun Aug 09, 2020 9:46 pm
by Nitrowing
mauri wrote: ↑Sun Aug 09, 2020 7:00 pm
That's impressive! My goal is 150kg but in full road trim.
I'd still like to see your list of modifications
