1962 Bullet gearbox problem
Posted: Sat Jun 27, 2020 3:42 pm
by 500Goldstar
Im having trouble with 2nd gear on my 62 Bullet,,,it either not stop in gear and when im changing from 3rd into 2nd its an hit or miss affair....before i start opening up the box can anybody point me into what type of the box needs looking at
cheers all
Re: 1962 Bullet gearbox problem
Posted: Sat Jun 27, 2020 11:48 pm
by TomCraig
Grab the kickstart shaft and see how much endplay you have, if a lot of play you're missing the shim that fits on end of trans. shaft.I have shimmed my own kickshaft to .010 and have eliminated the second gear miss.
Posted: Sun Jun 28, 2020 11:40 am
by vince
Hi, if the box was ok then started doing this the chances are worn or chipped dogs. However before going inside check the selector mechanism , this maybe worn or the springs are broken or weak. When was it last serviced? Bear in mind 58yrs of use. Vince
