By 500Goldstar
#91093
Im having trouble with 2nd gear on my 62 Bullet,,,it either not stop in gear and when im changing from 3rd into 2nd its an hit or miss affair....before i start opening up the box can anybody point me into what type of the box needs looking at
cheers all
By TomCraig
#91103
Grab the kickstart shaft and see how much endplay you have, if a lot of play you're missing the shim that fits on end of trans. shaft.I have shimmed my own kickshaft to .010 and have eliminated the second gear miss.
By vince
#91108
Hi, if the box was ok then started doing this the chances are worn or chipped dogs. However before going inside check the selector mechanism , this maybe worn or the springs are broken or weak. When was it last serviced? Bear in mind 58yrs of use. Vince
