Model G valve lifter, pushrods and rockers
Posted: Tue Jun 16, 2020 11:20 am
Hi, I have 3 issues with my 1951 Model G valve gear.
1- I am unable to get the valve lifter to work. the photo shows the lifter in the fully rasied position. As you can see, the lifter is nowhere near engaging, with the collar on the pushrod hex.
2- in order to get the correct valve clearance, the adjuster has to be screwed out so far, that there is only 3/16" of thread left in the pushrod. my first thought was the pushrod is too short.
3- the inlet and exhaust rockers are badly worn. Does anybody know where I can get them refurbed?
I appreciate issue 3 contributes to issues 1 and 2 but the wear on the rockers is appox .5mm
thanks in advance
thanks in advance
