- Sun Jun 07, 2020 11:52 am
#90553
My 2005 350 Bullet has a screw in dip stick. Should I measure the level of the oil with the dip stick screwed in, or just resting on the crankcase? I have just changed the oil, not including the filter compartment, after draining it from all 3 drain holes and the valve tappet chest. After adding 2 litres of fresh oil, the level is above the max if the dip stick is screwed in, but the level is OK with it unscrewed. Since I have only added 2 litres of oil and the capacity, I believe, is 2.5 litres would the “missing” oil be what is left in the filter housing?
