- Fri Jun 19, 2020 8:31 am
#90818
Yesterday I had the meeting with my dealer and the RE Aftermarket Sales Manager for Europe to find out more about the ticking sound in my 500 UCE EF with some frustrating results.
The manager intended to connect the dealers computer diagnose system to the bike to read out any fault codes. The dealer brought the brand new never used equipment and the manager had to explain the dealer and his staff the function of the system and how to use it. Ad hoc dealer schooling in front of the customer.
Concerning the fault codes – there were no ones. Next, the manager tilted the bike to both sides, but the ticking sound did not really change. Next, he fetched his smartphone showing a video to demonstrate how a defective hydraulic lifter sounds. A real proof that my hydraulic lifters have to be ok.
When turning the throttle the ticking sound on my bike was clearly audible. The manager had no real idea and stated the RE bikes are handmade and the quality varies, so each bike sounds different. Unfavorable tolerances may be the reason for the strange sound. For demonstrating and proofing this, he went to a second customer’s bike in the dealer’s courtyard and started the engine of this dirty, rusty and decrepit Classic 500 “Desert Storm” with a total mileage of 40.000 km. The motor was rumbling, the silencer emitted a cloud of dark smoke, but there was no ticking sound. The manager explained that there is a ticking sound, but you cannot hear it, as the other mechanical noise is so loud. A good proof that the ticking sound is quite normal and no reason for any activities.
Of course, I was curious which items inside the motor could create the ticking sound if we take in account that it suddenly appeared during a ride, and I asked this question three or four times in different ways. There was no satisfying answer, but the repeated statement that unfavorable tolerances may be responsible.
So I asked for the cam gear’s clearance as a possible reason. The manager commented that this could be the reason for the sound and advised the dealer to check it during the 3000 km inspection (what means to ride for further 1800 km with the strange sound of indefinite source).
One of the dealer’s workshop staff asked what is about the cam gear clearance and how to adjust it.
Well, the dealer tried to explain. In his opinion there are two gears just beside each other and the two gears are coupled by a common spring that will brace the tow gears to prevent any backlash. Well, there such constructions – but not inside a Royal Enfield UCE. I doubt that my dealer will be able to check the cam gear and adjust the correctly.
Afterwards I discussed with the After Sales Manager the usefulness of a Carberry vibration reduction plate in an UCE. As this plate is not a genuine RE factory product, he cannot say anything about it he stated. As the dealer never heard about such a plate the manager had to explain that such a plate would greatly reduce vibrations as there is an additional needle bearing installed in the plate that supports the generator-end of the crankshaft that itself runs only in two bearings and that the generator rotor may produce bad vibrations. Well, all this facts were completely new for the dealer.
I doubt that the dealer ever saw a RE engine from the inner side.
All this brought no news concerning the ticking sound of my engine, but some very interesting insights in the dealer’s competence.
Well, now I concluded that the best way to find the source of the strange ticking sound is to open the motor myself and see what I will find – no matter of losing the factory warranty. During the last fourty years, I maintained my motorbikes and kept them running myself without any dealer or workshop, with the help of my professional background in repair and maintenance activities.
I will update you when the source of the ticking sound is located and the noise eliminated.
On the eighth day, God created Harley-Davidson.
And he saw that it was a shit.
