Classic C5 Chain case
Posted: Tue May 26, 2020 2:41 pm
by Harryb
Hi,
The bike is a 2016 C5. There is a filler plug, labelled as such in the parts book, near the top of the chain case. Am I correct in assuming there is no need to put anything in as the lubrication comes from the engine oil? There is, of course, no level plug as was on earlier models.
Re: Classic C5 Chain case
Posted: Tue May 26, 2020 2:49 pm
by Jerseyplym
You're right there, the same oil is shared between the engine, gearbox and primary drive, so it doesn't need filling separately.
The filler on that side is for use in an oil change for putting some of the oil in.
In my experience though it's usually not necessary as it often doesn't drain completely anyway.
Posted: Tue May 26, 2020 5:08 pm
by Rattlebattle
It’s used for initial fill of a dry engine (0.3l) if I remember right. I’ll be using it on mine when I’ve completed the rebuild....No need in normal servicing but no harm in adding some through there either as long as the total measured qty is correct.
Posted: Tue May 26, 2020 6:45 pm
by Harryb
Hi,
That's a relief. Thanks for the advice.
