- Thu May 21, 2020 2:41 pm
#90209
C5 UCE 2015. I've been looking over the bike and find I'm having trouble seeing the oil level.
When cold the oil sits half way between the hi and low level marks, after a few minutes circulating I switched off but the oil fills the window entirely. Is this 'just' because my oil is dirty and generally obscuring the true level...If I have to wait for the level to appear then it will effectively be like coming to the bike cold with all/most of the oil drained back to the sump.
I see one can buy good old fashioned dipsticks...do they fit the UCE and if so which one would I need and would it measure resting on the thread housing or fully located.
I have a pronounced clanking on start up which goes away with a baby throttle blip. Any thoughts ???
I can see a minor mod for the air box ...the plate holding the air filter needs a flat nut to stop the assembly moving while trying to apply the plastic over-cover...just need to find a better seal that fits over the plastic edge.
Thanks in advance,
Thanks in advance,
