- Thu May 14, 2020 8:47 am
#90004
A switched live isn't entirely necessary for an ammeter. If there is no current flowing in the circuit, won't measure any.
Arguably, putting it in the non-switched live would be better, it would then indicate any parasitic power draw that was happening when the ignition is off. if you turn the bike off and the ammeter is deflecting, it means something is still drawing power and draining your battery.
That's how I have the one on my 350 bullet set up (I rewired it with a custom made loom). I even have a spare lead to connect a battery charger to and the ammeter shows when it's charging.
If you look at the battery, there will probably be two wires attached to the positive terminal. A big fat one and a thinner one. The big fat one is your starter motor, leave that alone. If you follow the thinner one, it will eventually come to a fuse holder of some sort. The ammeter needs to be connected into the wire that comes out of the main fuse (so if it develops a short or fault, the fuse will blow). I suspect this may all be very tight and well wrapped so a degree of butchery of the loom would be necessary and you may need to chase-through the wires with a meter to see which one you actually want.
You can't really do this in the back of the headlamp because you'd be "upstream" of the charging input.
If it was me doing it, I'd get some 2-core wire rated to 30A. I'd apply a crimp-on ring terminal to both wires at one end and attach these to the "posts" on the ammeter. I'd then fit the ammeter in the clocks (you may need a little rubber sleeve that goes round the outside of it) and double and triple check there is no way the posts or the terminals could possibly come into contact with any bare metal on the inside of the clocks in any way.
Next I'd neatly route that 2-core down to where the main fuse is. I like to use non-insulated bullet connectors with silicone sleeves, these need to be applied with a proper crimping die, not a pair of pliers. I'd pull out the fuse then I'd cut the wire that comes out of the main fuse (still sure you want to do this?). I'd attach a female bullet connector the the end nearest the fuse and a male bullet connector to the other end.
On the 2-core wire, I'd fit a male bullet connector on the wire that's attached to the left hand post (as you look down onto the ammeter face) and a femal bullet connector to the other one.
Now connect the wires. Power should be able to come out of the fuse, up to the ammeter then back down to the wire that used to be attached ot the fuse. Put the fuse back in. Turn the ignition on then off again relatively quickly while watching the ammeter. The needle should deflect down (how far varies, they aren't prescisely calibrated) but NOT bang off the stop! If it does, there's something wrong. If it deflected a little, go ahead and turn on and try the bike. It should go left when it's drawing power and right when the battery is charging, not necessarily by much. You normally see a very slight deflection to the right when all is well and the engine is running.
Now there are reasons I was very specific about where to put the male and female terminals. The first is that the female terminals are entirely covered by the insulating sleeve so we've put them on the "hot" ends of the wires to prevent them shorting if accidentally left dangling and touch the frame. The second is that you can't connect them the wrong way round. The third is, if you suspect an ammeter fault (remember, ALL the power to your bike is now running through a cheap, indian made ammeter!), you can easily reconnect the two ends of the wire you cut, effectively returning it to standard.
