Carburettor settings
Posted: Wed May 06, 2020 2:13 pm
by PO51UHD
Hello All
I’ve been assembling various bits ‘n pieces to make a Bulsader (535 Bullet engine in a Crusader frame). The head has been ported to match a 32mm Mikuni, and it breathes through a large conical filter and exhausts via a fairly free-flow silencer. Everything else is standard.
This afternoon I attempted to start it for the first time, and it ran (sort of...)!
In order to make it run even a little I had to wind out the idle mixture screw 3.5 turns, so the idle jet is obviously too large. It’s marked 3.25. Even with this I had to keep blipping the throttle to prevent it stalling.
Question is, what would be a good starting point for the idle jet? I believe the Mikuni and Mikcarb share the same jet system and size designations...
Thanks
Re: Carburettor settings
Posted: Wed May 06, 2020 2:35 pm
by mauri
for a standard bullet with open filter and exhaust and standard cams a 32.5 is good.
as the stationary circuit is better performing than the original micarb you should be able to run it on at 30.0 in some occasions even a 27.5.
be aware that a mikuni will not be able to start a cold engine without the choke!
as a main jet a 150 should be a good starting point, needle halfway.
Posted: Fri May 08, 2020 8:23 am
by PO51UHD
Thanks Mauri, I’ll give it a go!
Posted: Fri May 08, 2020 9:29 am
by McMurdo
Our hosts have a useful jetting guide here -
https://accessories.hitchcocksmotorcycl ... ttor-parts
Posted: Sat May 09, 2020 7:57 am
by PO51UHD
Hello, yes I had a look at H’s guide; not sure how to extrapolate for 535cc capacity and 32mm carb...?
S
Posted: Tue May 26, 2020 3:33 am
by Lou E
If you can get your paws on a Gunsons Colortune plug you can SEE the color of the combustion, and dial the mixture in to perfection. I use mine mostly on my 74 Trident as it is difficult to hear the differences while adjusting the airscrew..
