Wiring Diagram for Magura
Posted: Mon Apr 27, 2020 3:36 pm
by tribonnie
Hello, can someone please post, or point me to a website showing, a wiring diagram for early 1990’s Bullet that uses the left hand Magura switch. I think these are pre 1996 and kickstart only. Thanks Richard
Re: Wiring Diagram for Magura
Posted: Mon Apr 27, 2020 6:30 pm
by black fingernail
Mine has A Magura switch on it and it is a 1998. I recently re-wired it, but I cannot remember the colours and my notes are not to hand. There is a decent set of diagrams in Pete Snidals manual, but it is quite easy to identify the wires coming out of the switch by just unscrewing the front off, and inside is all to see.
Posted: Mon Apr 27, 2020 8:02 pm
by stinkwheel
I presume the magura ones are quite simple compared to the AC/DC ones, which are, in the words of Sherlock Holmes, a "two pipe problem".
Posted: Tue Apr 28, 2020 7:34 am
by PO51UHD
Hello
I have a ‘93 Superstar and when I rebuilt it I used one of those lh switch thingies. Took me a while to figure it out but I have a diagram.
Email me at stephen(underscore)herbert(at)btopenworld(dot)com and I’ll send a copy.
Posted: Tue Apr 28, 2020 7:40 am
by tribonnie
Black Fingernail (nice name)
Figured out most but can’t see haw the “flash” works.
I assume the flash will work without the other lights on
Is is just a simple switch to earth like the horn press
Thanks Richard
Posted: Tue Apr 28, 2020 4:25 pm
by black fingernail
Thank you kind sir.
There is a wire from the switch directly to the ammeter to power the flash, as well as the feed in to power the lights from the headlight switch, I cannot remember the colours.
If you wire everything else in you will have a spare wire that is the power in to feed the flash.
I hope this makes sense, I need a lie down!
Posted: Tue Apr 28, 2020 4:33 pm
by black fingernail
Don't hold me to it, buy I think it is brown, leading to the brown side of the ammeter.
Posted: Tue Apr 28, 2020 9:00 pm
by tribonnie
Thanks for answers
I do have a spare brown, think the think is connect up and see what works
Thanks again
