- Sat Apr 25, 2020 4:51 pm
#89546
Hi all, I’m looking for some help. I have a 1967 Interceptor Mk1 a and it has Developed a misfire on the left hand cylinder and is popping and banging in the exhaust.
I have stripped the carb and cleaned it, swapped the coils over, swapped the leads over, fitted new plugs and checked the valve clearances, all to no avail.
The right hand cyl is perfect.
I have compared compression on both cylinders by removing the plug and kicking it over and they seem comparable.
Oh it has electronic ignition fitted. Any ideas?
Thanks
Thanks
