oil seal
Posted: Thu Aug 23, 2012 7:37 pm
Hi all due to outside pressures the re build of my bullet has been delayed, and as it has been a little while since I stripped the parts and also my advancing years mentally,can anyone please tell me if the oil seal on the rear of the final drive casing from gearbox drive to clutch ,is there a spacer or does the seal ride just prior to the clutch drive splines on the shaft its self as it enters the final drive casing.
