- Tue Apr 07, 2020 12:09 am
#89009
Hello again.
I got dragging problem.
My bike is 2006 5 speed left gear change bullet 500(612 conversion).
I`m using improved 5 plate clutch and other things are stock.
The problem is...
I adjust clutch very well by following manual. (release all tension and release lock nut, adjust, feeling light resistance than stop and reverse 1/2~1/4 and lock again...)
and actually clutch is nice. no dragging no slip. but this sweet condition is collapse when I ride about 20 min.
I trying adjust clutch using screw of clutch lever but there is clear limitation. (I pull all cable than clicking sound came up from right side of gearbox when I using clutch lever)
and end of the riding, the gear is totally stuck so I can`t move the gear change lever to neutral.
I think some parts expanded by friction and it makes clutch diversion get more tight.
However I don`t have any Idea what exact happening in my gearbox!!
I usually ride my bike in downtown. (I live in Seoul. so...) Signal stand by could be make this problem?
of course clutch and friction plate expand when engine running but this clutch diversion spectrum is too wide.
I`m considering that using bearing pad. Is it good for dragging problem?
I waiting for your advice.
Thanks to read.
regards,
Lee June Woo
The problem is...
Thanks to read.
regards,
Lee June Woo
