- Thu Apr 02, 2020 1:53 pm
#88861
Rather than fitting two head gaskets, I would prefer to get a de-compression plate made. Two gaskets aren't designed to work together and it can cause a leak. Having said that, using one copper gasket next to the head, sealed with a non-setting sealant such as Wellseal, could probably be used with a normal composite gasket below that onto the barrel, fitted "dry".
I've just had a decompression plate made in aluminium for my trials car, which has a 3 cylinder, 993cc supercharged engine. On this engine, a 1.5 mm thick plate lowers the CR from 9.5 to 8.25. Because the block, being from a car, is all in one piece, I had to fit the plate adjacent to the cylinder head casting (with a sealant, as above)and a normal head gasket between the plate and the block.
However, on a bike engine like the RE, it's more straightforward because the plate can be fitted below the barrel, with a base gasket on each side.
