- Thu Apr 02, 2020 12:54 am
#88840
Hello from South Korea.
I got pinking problem.
My Enfield is cast iron 612 conversion bullet with crank, cylinder, head and VM32 carb.
(no high performance cam)
and I`m Using 20T gearbox sprocket. 20t sprocket upward tendency gear change timing about 20km/h(12.4 mi/h)
so. problem is, when the speed reach 80km/h (49.7 mi/h) at gear 5, pinking is start when I pull the throttle more.
sometimes gear 4 also makes pinking sound when I pull the throttle hardly.
of course when I tried pull the throttle carefully, pinking is much less but there is a clear limitation.
because of these reasons, I use only 1/4 ~ 2/5 throttle at 4, 5 gear speed.
I tried retard ignition timing but engine getting unstable and loss power(or maybe my carb setting is wrong)
however, the 20t sprocket gear ratio can be the main problem I guess. because engine get much more load when
I changed 17t to 20t.
Should I change the gearbox sprocket smaller one for solve the pinking problem?
or is there a any options like ignition timing setting, carb setting, or others?
Please help me.
Thanks for read.!
Please help me.
Thanks for read.!
