- Sat Mar 21, 2020 11:23 am
#88474
I agree, hydraulic tappet adjusters only need to be filled with oil to work. I’ve just rebuilt a car engine with a reconditioned cylinder head and fitted a performance overhead cam to it. The cam followers and cam went onto the head weeks ago; I had filled them up with oil at that time and have obviously not topped them up since. Yesterday afternoon I cranked the engine over using a spanner on the crankshaft nut with the cam cover off to check everything was in order before finally getting ready to start it. The tappets were fully charged and the valves opened fully. There was no oil pressure in the system at all at that time.
However, a couple of years ago this same engine suffered an intermittent failure of the pressure relief valve in its oil pump; it tended to stick fully closed when the engine was cold. The oil pressure intermittently went off the top of the gauge on start up (it reads up to 100 psi). I initially thought the gauge had begun to fail.....I soon realised this was not the problem, I was more interested in the severe misfiring which occurred at the same time. In retrospect, I think the reason for this was that the pressure was going high enough to pump a couple of tappet adjusters up so hard they held their valves off their seats. It misfired like mad - until the oil filter canister deformed enough to allow the sealing ring to the block to be blown out. The pressure went from off the clock to zero in about ten seconds because that’s how long it took for the pump took to empty the sump! It made a hell of a mess both inside the engine bay and on the ground.
