- Thu Mar 19, 2020 5:58 pm
#88438
Hi , I'm new here ...old to Enfields . Having worked on quiet s few other bikes Nortons BSAs Triumphs and others the most striking difference is the oil pressure at the crank . The Bullet 350cc that I checked had around 3 to 5 pounds / inch at the timing cover nut . Seeing that this is a white metal floating bush type big end it has double the clearance and double the start up contact heat to handle . My question is simple ' what are the two extra holes in the pump body for ?' Now I've gone through the manuals so would request less quotes from them Thank you
