- Sun Mar 15, 2020 10:29 pm
#88363
I did (and completed!) my first long distance trial on my 2007 350 bullet today.
The many varied inadequecies of the build and rider notwithstanding, I did have a particular issue. When going over an abrupt down incline (so say a 2ft drop into a ford), the engine stuttered and conked out.
It did the same thing 4 times. Three times dropping into a ford, leaving me to restart in the water and once on section dropping into a gully. If I was on a mountain bike, I'd have called them "drop-offs". The last time it happened, I conciously gave it more gas as I went over the edge (which is not what I really wanted to be doing) but it still did it.
I'm totally convinced the water was not a factor, it happened too quickly and I went through WAY deeper water today with no problems. In fairness, I probably went down much steeper inclines too, it seemed to be the sudden downslope that triggered the behaviour.
I'm thinking float height and the possible solution is to up it a little or even make a manifold with a slight down-angle so the carb sits more level when on a downslope. It has a standard mikcarb jetted to suit a pod filter and trails pipe. Running a little rich if anything.
Just wondering if anyone else has experienced similar issues?
