- Thu Mar 12, 2020 12:30 pm
#88328
Although this is drifting the subject slightly, I’ve always been surprised to hear from various sources that nylon lined cables don’t need to be lubricated.
In my experience, what kills any cable is corrosion. If an inner gets rusty, it becomes harshly abrasive and wears the nylon liner away in a very short time, then itself gets worn away against the outer until a strand breaks. Then it’s game over.
So these days I always use a good, oily lubricant on all cables and re-lube them using a pressure lubricator at least once a year, or every time I need to disconnect one for other maintenance reasons. I can’t recall ever having a cable problem since doing this. The cables on my 29 year old Honda 750 are the originals and still operate as smooth as silk and have no signs of rust, even at the exposed ends.
