Magnito Removal 1957 350 Redditch Bullet
Posted: Fri Feb 28, 2020 1:16 pm
Hi All. Thanks to previous info on this site I have now exposed the auto advance unit removing the exhaust and timing cover My 1957 model has a nut rather than a screw and nut retaining the AA unit on the magnito rotor but I am aware how to remove it by unwinding the nut anticlockwise. Before removing it however I have exposed the points plate on the magnito looking for the 3 screws that apparently hold the magnito, as I understand it, to the timing chest. They do not seem anywhere obvious to me and I am therefore wondering how far I need to go to remove the 'innards' of the magnto to get at them. as I wish to disturb as little as possible given that the cam plate was factory set (63 years ago!) for maximum spark when I reinstall after the relevant testing/repair, Apology if these post seem rather basic as this will be my first time have dealt with this and my mechanical skills are fairly basic. i have set bike to TDC on compression stroke in removing above in the probable forlorn hope that this will minimise disruption on reassembly. Also paint marked timinggears to current position. Any advice appreciated. Thanks Hugh
