- Sun Feb 23, 2020 9:57 pm
#87991
I have the top end off the 2006 Electra X as did have a horrible noise develop, turned out to be piston slap and one wrecked piston and slightly less wrecked liner, so job to do there and considering options, big bore, high comp etc. Big end seems ok but the little end seems to have a problem. Piston off and gudgeon pin out I can rotate the bush, no play as such but can rotate it, my worry is the oil hole will move out of alignment, is this ok or is the bush supposed to be a tight fit in the con rod? I can also push the bush left and right, it won’t come out but will stick out about 10mm from the conrod, pushes back in with ease. There is no play but just a very smooth fit?
2006 Electra X and 2008 350T Bullet Watsonian Trails conversion
