- Sat Aug 18, 2012 5:45 pm
#1024
Hi all,
I have a 1955 Bullet 500cc with an approx 1990 Indian engine. Sometime in its past it has been rewired and doesn't resemble any of the wiring diagrammes I can find. Obviously I don't have quite a few parts which are on more modern Bullets (no indicators, no full/dip lights on the speedo etc. etc). Since I've had it the ammeter has never worked. I replaced the ammeter wondering if this was the problem, but still nothing - well hardly anything - it does show a slight negative movement when I have all the lights on. It doesn't show the dip to the left as the engine is turned over before starting for example....
I've been trying to trace the wiring. There are only 2 connections on the ammeter. On one side I have 2 Br/Bl wires. One seems to go to one terminal of the horn and the other disappears into a loom and I can't trace where it goes at the moment. On the other side are 2 Br/Wh wires. One seems to go to the light switch and the other to the ignition switch....
So, does anyone have any idea what the wires should be connected to, and whether this seems to make any sense? I thought it may just be a bad earth, but everything SEEMS to be fine, everywhere I've checked.
Thanks in advance for any advice.
