- Thu Feb 06, 2020 10:47 am
#87675
I would appreciate advise on how to remove the top rear shock bolts on a 2018 Classic Euro 4 EFI C5.
The bolt pulls out from the inner side towards the mudguard and there is not enough room to remove it before if fouls the mudguard. The nut is on the outside, i would have thought it would be the other way round!
I need to put longer bolts in as I have pannier frames fitted and will also be fitting rear crash bars and a RE rear carrier; all bolting to the top shock bolts.
Thanks in advance.
Thanks in advance.
