- Sat Jan 25, 2020 4:38 pm
#87411
I'm going to keep the 19" rim on my 2007 350 bullet for the time being until I decide if I enjoy this kind of riding. Not rock-hopping type trials, the ride on the road then try to get up a muddy/gravelly track section type trials .
I could fit a 3.50 or a 3.25 on the front. Either will fit, I left plenty clearance around my mudguard. Enought to go up to 21" later if I want to (but I'll need to cut the bolts off neater if I do).
So 3.25 is the size the bike is supposed to have, would the wider 3.50 be an advantage in terms of grip-patch surface area for trial riding? Will it be a problem in terms of on-road handling?
Regarding the rear, I'm pretty sure 3.50 is the de-facto widest tyre you can fit without changing the swingarm?
I do intend to fit rim-locks.
In any case, I need to order a new front before the Dragon rally. I was chuffed when my ebay wheel came with a tyre on but I just checked the date code. it's 13 years older than the bike!
