Long Shocks - supplements question
Posted: Tue Jan 21, 2020 5:14 pm
by PO51UHD
Hello All
Rather than hijacking McM’s post, here’s a supplementary, related question.
I’m in the process of shoehorning a Bullet engine into a Crusader frame and have installed long shocks to lift the rear and Bullet forks to lift the front. Having just installed the rear chain I find the top run just contacts the top of the swingarm.
Is this a problem and should I somehow fix some rubber or nylon to the top of the swingarm (rather like the bonded rubber on the primary chain tensioner)...?
And if yes to both questions, where do I get suitable material?
Re: Long Shocks - supplements question
Posted: Tue Jan 21, 2020 7:38 pm
You might be able to come up with a swinging arm guard using some of this:
https://www.ebay.co.uk/itm/HDPE-Flat-Bl ... 0005.m1851
Mind you, I've seen roadster Bullet swinging arms where the chain has started rubbing away at them.
Posted: Tue Jan 21, 2020 10:58 pm
by McMurdo
As you say I’m also going through these questions so I’m happy to share what I’m trying.
For the swing arm area I’ve ordered one of these guards - https://rover.ebay.com/rover/0/0/0?mpre ... 2197524124
I’ll cut it half and use car badge tape to secure it (just because it’s in my adhesives drawer)
To allow for more chain movement but still keep the tension I’ll use one of these - https://rover.ebay.com/rover/0/0/0?mpre ... 4039207137
It’s surprisingly well made for £12 but took a while to walk here from China!
My shocks arrive this week so I see some fettling in the near future
Posted: Tue Jan 21, 2020 11:09 pm
by PO51UHD
Thanks for both suggestions. I’ll have a proper look and try one!
Posted: Tue Jan 21, 2020 11:48 pm
by McMurdo
If you're just after a suitable hard-wearing material then go to your local cook store and buy a cheap nylon chopping board. I was thinking about going down that route but I need to wait until my wife isn't looking :D
Posted: Wed Jan 22, 2020 7:32 am
by mauri
as there is no much room for a chain guard, be it on a bullet swingarm or crusader.
this one fits nicely
https://www.feked.com/bultaco-swinging- ... 78-82.html
its fixed this way to the swingarm(chain has been pulled to the side to make picture)
