- Sat Jan 04, 2020 7:15 am
#86981
Hi Guys. My 1996 Bullet (Indian model) has developed a bit of play in the forks – no, not the steering tube bearings. After some 20000kms I guess it is to be expected. Our hosts parts book only shows an upper bush (fork cover bush PN 141427). Is there no lower bush? I don’t want to strip the front end and find I don’t have all the parts because I live far away in a country where even courier services get delayed. But I do need to cure the wander that is developing, especially at speed!
BTW the electronic ignition from BoyerBransden (its a twin-plugged 535cc high compression) works well giving me an excellent slow idle and plenty more power. This is because the sparks are always at the right time and the advance is smooth instead of the advance being challenged, too early and the sparks coming at somewhat variable times (strobe-lit markers show a 10degree wide band instead of a sharp line). Top speed is unknown so far because the handling scares me above 75mph but it will do that easily at half throttle.
Cheers, ChrisD (yes, 75mph at 4300rpm with a 19T drive sprocket, 32mm carb, larger valves and flowed head etc, etc, etc).
