Unsticking stuck barrels
Posted: Sat Dec 28, 2019 7:00 pm
by Tomshayes1
Hi Guys
I am undertaking a frame up rebuild of my 53 Meteor.. I have removed the engine and box and am stripping the engine down for ans inspection measure and clean up. . Heads are off but I cannot budge the barrels... I glued them on with Wellseal and well they're well stuck... Any ideas re soffenting up the Wellseal would be appreciated.. The studs are removed so nothing but Wellseal is holding the cylinders on.
REgards
Tom
Re: Unsticking stuck barrels
Posted: Sat Dec 28, 2019 7:50 pm
Hot air gun? Blowlamp? Or have you already tried those?
Posted: Sat Dec 28, 2019 8:24 pm
by Tomshayes1
Hi Adrian
Not yet I'll give it a go..
Tom
Posted: Sun Dec 29, 2019 8:08 am
by windmill john
I had a similar issue on a Honda. I rigged up a stand that it took the weight ( in your case) of the barrels and left the engine suspended in air off the bench; obviously only half an inch or so.
Be careful to support the fins. I then sprayed all sorts of lubricating/releasing things round and inside the barrel and left it a week. This sufficiently loosened it enough (not visibly) so that some more pulling and grunting separated it.
John
Posted: Sun Dec 29, 2019 10:23 am
by Aethelric
A kettle full of boiling water poured over the join followed by a few taps with a wooden mallet was worked for me on occasions .
Posted: Sun Dec 29, 2019 10:41 am
by Bullet Whisperer
Very careful work with two or three Stanley knife blades can work. Hold them flat and tap them into the joint with a light hammer, they will usually go in a bit at a time, in turn, without doing any harm and the slight taper of the knife edges will impart very slight, but very strong 'lift'. This method works very well for me with crankcases which do not want to part and, with care, no damage will be done.
Posted: Sun Dec 29, 2019 1:02 pm
by papasmurf
Tomshayes1 wrote: ↑Sat Dec 28, 2019 7:00 pm
Hi Guys
REgards
Tom
If you are doing a complete engine strip down take it to bits as much as to you can, and dunk the rests- in diesel for a month, it will come apart then.
Posted: Sun Dec 29, 2019 6:34 pm
by Tomshayes1
Thanks for the tips guys a few to try there.
I will let you know how it goes
REgards
Tom
Posted: Sun Dec 29, 2019 11:04 pm
by stinkwheel
Just thinking out loud, could you make effectively a giant strap wrench using a bit of thick webbing and a lump of wood and try to rotate the whole barrel?
Trouble is wellseal uses some nasty-arse solvent in the first place. Looked it up. Perchloroethylene. You can buy it on ebay as dry cleaning fluid though.
MEK might be worth a bash too? Not much that won't soften.
I'd imagine filling the stud holes to slightly above the level of the base gasket would be the best way to get your chosen solvent in there for a "soak".
Posted: Mon Dec 30, 2019 3:14 pm
by Tomshayes1
I used the Stanley blade WD40 heat and brute force method...
![Image]()
