By John G
#86820
I had problems with the right rear indicator on my '05 bullet, first the earth disappeared, fixed that with a bypass wire, then the live disappeared, so I probed around with a multimeter to try to identify the problem. Eventually I took the rear housing ( the affair that holds the number plate. etc) off, and the problem was immediately obvious ---- The snap connectors had pulled loose, thus rendering the rear indicator useless. The connectors looked dodgy, :roll: and it may have been vibration that pulled them free. So if it's not the bulb, it more or less must be a snap connector.
