- Mon Nov 11, 2019 8:04 am
#86413
Does anyone have experience of “performance” cams against “fast road” cams in a Bullet – preferably a 612?
As some of you know I bought my old 612 Bullet back last year after selling it in 2013
When I sold it, it still had the standard Indian cams in it, when I bought it back I found that it had been fitted with “performance” cams.
From memory with the original Indian cams fitted it felt like it had a lot more bottom end, the performance cams don’t have the same bottom end performance as the Indian cams – they work better the harder you ride it, which I guess is pretty much what you would expect.
Guess that the fast road cams will further decrease bottom end performance but give a little more at the higher end of the rev range - or do they give a better spread of power?
Think that I can also gear it up a little as I am running a 19t gearbox sprocket – it feels like it could take 1 maybe 2 teeth more on the gearbox sprocket for more relaxed cruising, and less hurried up shifts in the lower gears.
Interested in the thoughts of the forum.
Previous bikes - far too many !!
