650 Interceptor gear change indicator
Posted: Mon Oct 28, 2019 9:51 am
by fjrwheels
bought an orange crush late Jun. covered 3000km now with no issues. anyway, thought i would show you all my gear indicator dashboard. was forever forgetting what gear i was in....must be an age thing !
anyway, three attempts later and this last result is what i come up with. hope you like it.
Re: 650 Interceptor gear change indicator
Posted: Tue Oct 29, 2019 9:23 am
by PO51UHD
Interesting!
I have similar age-related gear forgetfulness ...
What did you fit and how?
Posted: Sat Nov 02, 2019 10:26 pm
by Lou E
Nice!
Posted: Fri Nov 22, 2019 1:54 pm
by fjrwheels
Found a universal one on e bay. It was cheap enough, so thought I would give it a try. Found a live and ground plug not being used inside the headlamp. That’s the power sorted. Also found the neutral wire and piggy backed off that. After that, it was a matter of the two sensors to sort. Made a bracket, stuck the sensors to it and glued it behind the gear selector shaft. After a bit of jiggling and poking with the exact position of the sensors, all worked fine.
Posted: Fri Nov 22, 2019 11:55 pm
by Leon Novello
What happened to being able to tell which gear is engaged by listening to the engine, or the vibrations through the seat , handlebars, foot pegs or rattling teeth?
Posted: Mon Nov 25, 2019 9:30 am
by Presto
I recall an interview with Mike Hailwood; I believed he was asked about his Honda ‘six’, and how many gears the bike had. He answered that he didn’t know!
Posted: Mon Nov 25, 2019 10:11 am
by Wheaters
Leon Novello wrote: ↑Fri Nov 22, 2019 11:55 pm
What happened? They improved the bikes, made them quieter, vibrate less and fitted more gears.
Posted: Mon Nov 25, 2019 10:47 am
by Presto
I’m not sure why you need to know the number of the gear you’re in – if it’s too low change up; if it’s too high change down. Whether it’s called 2, 5, 6 or 8 seems to me to be irrelevant. The right gear is decided by the riding, not by numbers.
But I guess a gear indicator is a nice extra.
Posted: Mon Nov 25, 2019 7:31 pm
by Wheaters
Most useful when coming to a stop, so you know exactly where to find neutral, also when about to set off again.
I've only ever had one bike with a gear indicator light; it was a 1981 Suzuki 400 with a six speed box. I used it to commute on, often in heavy traffic. Trying to set off in too high a gear just didn't work.
Posted: Tue Nov 26, 2019 9:50 pm
by Leon Novello
My 2000 Bullet had 45 neutrals, so a light might have been useful on that bike..
